What SCR should I use for low power
chistir
Joined Feb 15, 2025
Hi I am a 1st year electronics student and I'm trying to make a light bulb dimmer circuit for my presentation but I am not sure what SCR I should or if my circuit is possible. I'm planning on using a 3v light bulb for my circuit. Is it possible? what SCR should I use?
Ian0
Joined Aug 7, 2020
13,215
Any SCR will work. A filament lamp will have an inrush current of 10 times its running current, so don't choose one that is too small. Look for one with a gate current suitable for your trigger circuit.
But don't forget that they will only work on AC if you want to make a dimmer.
And also forget that they will drop 1Volt, so if you have a 3V AC supply, you will only have 2V left for the lamp.
Using a SCR at low voltage makes no sense since AK drop will be about 0.8V at least, so it will lead to very poor efficiency.
I would not use a SCR even at 12V.
Use mosfets or Bjt-s instead.
schmitt trigger
Joined Jul 12, 2010
2,171
One thing to consider with SCRs is the holding current. Your load must consume more current than that, otherwise the SCR will not latch.
Do you know the load current? Based on that we could make device recommendations.
27,962
What is the motivation of selecting 3 volts??
At that voltage you can use a transistor to vary the current and dim the 3 volt bulb. Is the plan to use battery power???
There are a lot of details missing.
