Which Route should I go with for power?
tdengineer
Joined Oct 21, 2025
38
4 layer board
Top layer = RED
inner 1 = GROUND
inner 2 = GROUND
Bottom layer = BLUE
Green Route or White Route
Green Route goes under IC and I dont know if that will cause problems or interact with the ground vias under the ic in any way when the spi signals return through them
White Route goes under my RF Trace and I dont know if any RF waves going through vias could somehow couple their way into the power trace/
ronsimpson
Joined Oct 7, 2019
4,884
4 layer board
Top layer = RED
inner 1 = GROUND
inner 2 = GROUND
Bottom layer = BLUE
Top layer = RED
inner 1 = GROUND
inner 2 = power
Bottom layer = BLUE
Remember; power and ground need to be connected together many times with bypass capacitors.
----------editrd--------------
I think, on a different post, you worried about the energy on the edges of the SPI signals. That energy also passes through the ground and VCC pins.
I moved a bypass capacitor close to the IC power pin. And connected the VIA close to the IC pin. Use wide traces for power and ground.
