What Schottky diode for protection?
Nicholas
Joined Mar 24, 2005
139
Hi guys
Thus far I have used a 1n1001 normal diode in series from my controller (5V) to my MOSFET switching something like 30-50V.
I want to use a Schottky diode to get a smaller voltage drop from the controller, but I would like a recommendation as to which one.
The Schottky should protect the micro controller in case something goes wrong, and 50V is going out of the gate of the mosfets and
try to fry the micro controller. I have been adviced that this is very rare, but I want to be on the safe side :)
So, what Schottky should I use?
Thanks!
Nicholas
Joined Mar 24, 2005
139
About the SS110 Schottky diode, I use through-hole components only, as far as I can see
the SS110 is surface mount, right?
Sensacell
Joined Jun 19, 2012
3,453
While I understand the instinct to "protect" your microcontroller, a series diode in this case is not really a good idea.
1) You need all the gate voltage you can get to turn your FET on, the diode subtracts ~0.5 v from the gate drive
2) With the diode in place, the fall time of the gate drive will be extended, the only path for current flow is the 10K resistor. Without the diode, you have symmetric rise and fall performance.
Your flyback suppression diode will short, or the IRL540 will short (never open). The worst that can happen is that your PIC output port will be grounded if it is set as an output. The 1k base resistor will limit the output port current to under 25mA, but they can handle up to 100mA, I've found.
Nicholas
Joined Mar 24, 2005
139
What is my flyback suppression diode in this case?
I get the gist from a lot of people that I should not use a diode for protection at all. It just makes me a little nervous :)
OBW0549
Joined Mar 2, 2015
3,566
It's the diode connected across the inductor.
I don't think you really need protection here; but if you're sure you want some, then a simple Zener diode, such as a 1N4735A, connected between the MOSFET gate and GND should suffice.
Nicholas
Joined Mar 24, 2005
139
OBW0549, I was recommended using that a zener between gate and ground earlier, this might be the way to go.
Does it matter if it is connected to micro controller output-pin side of the 1K resistor or the gate side? See drawing below:
OBW0549
Joined Mar 2, 2015
3,566
Connect it to the gate side, NOT the microcontroller side. The Zener will clamp any incoming positive spike to ≈6V, allowing the 1kΩ resistor to limit any current that might find its way into the μC port pin. Connecting the Zener directly to the port pin accomplishes nothing.
Nicholas
Joined Mar 24, 2005
139
Okay, so like this:
Also, this should take of any voltage drop from the 5V from the controller, like I had with
a normal diode, right?
Nicholas
Joined Mar 24, 2005
139
To prevent voltage from going back into the micro controller, I had a normal diode in
series with the 1K resistor. This cut the 5V to 4.3V, which I thought was too much of
a loss.
Using the zener method, the 5V from the micro controller should reach the gate of the
MOSFET, right? Not being lowered to 4.3V or 4.5V.
Thanks!
Picbuster
Joined Dec 2, 2013
1,047
Okay, so like this:
Do not use zener protect your mpu output. This is slow and uses a lot of power. (>300 micro amp)
The best way is to clamp to MPU's VDD with an ultrafast schottky and one to GND to eliminate the negative part.
Make sure that the unwanted signal is consumed by a resistor.
So, at dangerous site via resistor two diodes one to mpu vdd one to gnd. junction to mpu you want to protect. (see attached)
Resistor = (vmax-vdd)/ ( acceptable current ) (for positive pulse)
Resistor =(Vmax)/(acceptable current) ( for negative pulse) ( breaking a wire will create a diffentiator (serial capacitor) as result a negative pulse)
Energy in resistor (W)= I^2 x R
Nicholas
Joined Mar 24, 2005
139
Okay, I am confused about which direction to take, now :)
If I were to use a Schottky diode in series from pin output to gate, what value should I use?
Thanks,
Nicholas
17,498
The scheme provided by Picbuster (middle right box) is very thorough for protecting the MPU from any voltage placed on its output that is not within the power rails supplying it. However I would leave the pull-down resistor in place (gate to ground) to ensure against the MPU failing to "open", or "float", some undefined state. The resistor shuts off the MOSFET if that happens. It's a small risk but a very small cost for the insurance against it.
As suggested, don't put any diode in series with your MOSFET gate. Leave only a current-limiting resistor in that position. Your 1k should be fine.
Nicholas
Joined Mar 24, 2005
139
Does it make any difference to the solution that I am driving a coil(probably) at the mentioned ~50V and 10A?
The reason for not using a diode in series is the voltage drop, right? But with a schottky, this should still leave something
like 4.6V or a little more, which should be enough to saturate a logic level MOSFET or?
On picbusters scheme, titled Nicolas :), one schottky is going from the output pin to Vdd, what voltage is this? Is it the voltage
used to drive the solenoid? (50-ish). Also, what exact value schottky diodes should I be using? By the way, thanks for the picture
picbuster!!
So, the zener method is not good then?
17,498
No, those two diodes go to the two power rails of the MPU. This ensures that the output pin voltage cannot get more than one diode drop higher or lower than the range between the power rails. Any voltage outside that range is then conducted by one diode or the other to the power rail itself, and away from the MPU output.
Placing a zener on the pin to protect (as in #10) is commonly done for input pins and I don't see anything wrong with it here. As long as the output is normally below the zener voltage, I don't see the zener doing any harm and it does offer protection.
I do not understand the objection to #10 from OBW0549. The zener in #12 would pop like a fuse if any significant voltage came along to challenge it. There's nothing to limit the current. Arrange as in #11, the 1kΩ resistor limits the current that the zener needs to sink to protect the MPU.
