what resistor values for the output pins
DickCappels
Joined Aug 21, 2008
10,662
The resistors are there to reduce the chance of destructive ringing and oscillation on the gate of the MOSFET.
You may notice that there are no examples in the datasheet in which gate resistors are not used.
Whether you can connect the sink and source pins together does not appear to be addressed in the datasheet. That could save one resistor if it doesn't break the driver.
DickCappels
Joined Aug 21, 2008
10,662
Unfortunately, people talk of zero ohm resistors. How's that for setting things up for confusion?
If you find excessive ringing on the gate, which would manifest itself as poor efficiency of the MOSFET, you may wish to try the resistor.
BobaMosfet
Joined Jul 1, 2009
2,211
There is this circuit with no resistors straight from the datasheet.
You need to learn how to read a schematic. There are at least 3 resistors shown in the image you posted (Rin, Rsouce, and Rsink). As for 'zero-ohm' resistor that is a lie and a myth. There is no such thing (unless you want to call it a conductor). Resistors serve one and only one purpose- to resist the flow of current. Out of this manifests many valuable things related to manipulating the reciprocal relationship between voltage and current.
djsfantasi
Joined Apr 11, 2010
9,237
I’m not clear as to what you mean. I get that the name “zero-ohm resistor” is meaningless. However, as a component, they most certainly exist. Mouser has many (10,000+) zero-ohm resistors for sale. So does DigiKey!
BobTPH
Joined Jun 5, 2013
11,615
And they are very useful in laying out single sided PC boards with SMT components. (Use them to jump one track over another.)
Bob
DickCappels
Joined Aug 21, 2008
10,662
If I read the datasheet correctly, only one of the output devices (source and sink) are on at a given time. Only one of the lines is a low impedance at a time, so with 8R resistors there would be 8 ohms in series when the gate is being charged and held high and different 8 ohms while the gate is discharged and held low.
BobTPH
Joined Jun 5, 2013
11,615
It is a gate driver. All it is designed to do is charge the gate of a MOSFET. Take the total gate charge and divide by 10 to get the time this takes.
Current stops flowing once the gate is charged. It can be left on for as long as you like. It
Bob
38,680
If they are identical value, I see no reason for separate source and sink resistors (unless they are being used to minimize shoot-through currents).
Audioguru
Joined Dec 20, 2007
11,248
If the gate driver IC is very close to the gate pin of the Mosfet then there is no inductance in series and there will be NO RINGING. Therefore then the sink and source pins of the gate driver IC can be connected directly to the gate pin of the Mosfet with NO RESISTORS.
The datasheet shows the fast waveform produced (with some overshoot) by the Mosfet when there is NO RESISTORS. The overshoot would become ringing if there is some series inductance caused by distance between the driver IC and the Mosfet.
jpanhalt
Joined Jan 18, 2008
11,087
Here's another viewpoint (see attached, AB-9). Use what you need to reduce ringing to what you find acceptable. You can use a diode to speed up turn-off, if necessary. Unfortunately that pdf is no longer on the Fairchild site, so far as I know. I see no reason for multiple resistors as shown.
Audioguru
Joined Dec 20, 2007
11,248
A wire or trace has series inductance that is reduced if it has a very short length. The inductance resonates with the gate to ground capacitance of the Mosfet which causes the ringing. Adding a series resistor slows the rise and fall times and reduces the Q of the LC tuned resonance.
