What part is this?
38,526
I not found a SMD code marking with 4 digit in line to compare.
Why do you say that?
The one posted in post #2 does.
Your diode has 5817 on it, and it has catastrophically blown which overcurrent through a diode could cause, so I also vote that it is a 1N5817 diode.
sagor
Joined Mar 10, 2019
1,050
It is a diode, as those extra green wires are to allow more current to pas through it. The pcb traces are probably not heavy enough for the current.
But, find out what caused the failure in the first place, else the replacement will blow as well.
