What operating system do you use?
  • Windows 8 / 8.1
    Votes: 7 17.9%
  • Windows 7
    Votes: 16 41.0%
  • Windows Vista
    Votes: 1 2.6%
  • Windows XP
    Votes: 9 23.1%
  • Linux (like Mint, Ubuntu, Suse etc.)
    Votes: 4 10.3%
  • BSD
    Votes: 1 2.6%
  • others
    Votes: 1 2.6%
  • Total voters
    39
Wendy
Joined Mar 24, 2008
23,809
M$ are dead and gone. An important but unpleasant part of tech history.
In the same way that Hitler taught the world how not to behave, M$ taught future tech companies how not to behave.<snip>.
Are you looking at the same poll I am?
Mr.Gates retired fairly young as one of the worlds richest men. I think he definitively won the rat race.
I'm rooting for Linux, but it has a long way to go.
Brownout
Joined Jan 10, 2012
2,390
When I got my new Win7 computer, I had it all set up in about an hour. Still trying to get Linux set up after working for weeks. Windows isn't going anywhere anytime soon.
30,787
Unfortunately, historically, often the case with many inventions/developments, the best does not always come out on top, MS had a lot of money thrown at it which drowned much of the competition, many were superior P.C's and operating systems.
The cream does not always float to the top, depends who's stirring the pot.:rolleyes:
markdem
Joined Jul 31, 2013
113
Good too see the spelling protection agents are still around. I think for someone whose first language is not English I still do quite well....
Maybe you were lucky not to have suffered the Nvidia update lockout, or perhaps the black screen of death, to whcih there is still no known solution other than full reinstallation of Windows.
I assure you there are plenty of reasons that Windows can suffer uneccessary crashes
This is what I am talking about. Nvidia releases drivers that are crap and it is somehow the fault of Windows. How is Windows meant to protect itself from this? Windows does quite well at protecting as much as it can, but it can only go so far. Which OS can you name (that runs on a PC) that does not crash?
(In saying all this and not having the issue myself, could you not boot into safemode and uninstall the drivers?)
What Microsoft would need to do is take Apple's approach. Limit the hardware and software to only tested and approved vendors. But then you would have people complaining that they can't install the latest <insert hardware here>. You just can't make everyone happy....
There are many tasks you cannot perform as an admin, without using elevated status.
The simplest is turning hibernation off - a highly recommended setting to make.
Hmm, I just turned my on and back off and did not get any prompts. I wounder what the difference is..
studiot
Joined Nov 9, 2007
4,998
@markdem.
I would be glad to discuss details of Windows with you, but in another thread if you care to start one.
In particular I would be interested to learn what you did to turn hibernation on and off since the tab was removed from the control panel after XP.
As far as I know you need an elevated command prompt to achieve this in later versions.
But this thread is about what OS people use.
markdem
Joined Jul 31, 2013
113
@markdem.
Sure. I simply went to the advance settings in the power plan and set the hibanation timer to "Never".
However, to split hairs, it does not really disable hibanation, it only turns it off. However, I would think for most users this would be fine.
(I do aggree that you do need to have the cmd window running as admin to user powercfg).
studiot
Joined Nov 9, 2007
4,998
Obviously the second-user spellchecker I sold you still has the same glitches.
:D
But thank you for that ingeneous way round the issue.
Do you not also need to make some other setting in power plan so there is no conflict, eg making sure hibernation is not set as the default option on closing the lid?
atferrari
Joined Jan 6, 2004
5,022
Most of the complaints about Windows are issued by users, not professionals versed in programming and it is what we should expect.
Myself, just an user, I have lot of complaints too, believe me, and always called Microsoft trying to solve the issues (with less than good results, always).
But then, I wonder, where / what was doing that huge mass of qualified complainers at the time Guillermo Gates and his partner started to developed it? With the Monday's newspapers I can also say who won the elections.
If you consider this like spitting in the Cathedral, OK, then, here you have more:
I've heard of Linux from long time now [and in my next (blank) machine still to be assembled it is going to be the first thing I will try], as kind of friendly thing that would not obsolete my hardware for a long time.
Just posting few questions about starting, most of the warnings / reccommendations I got were about getting more powerful HW and beware of the learning curve.
Should I understand that people offering advice is not always actually qualified, that products are far from being the equivalent of common cars where you need little to drive them properly even if knowing nothing about the innards of the vehicle?
I used to complaint a lot about the surprises that MPLAB by Microchip offered in their frequent new versions. Finally I gave up. I suspect that I could never change antyhing of it.
After complaining to Microsoft about the difficulties I face to find out who sells locally an original Windows, I could say I gave up too.
If a moderator decides to delete this mixed rant outright, I will not complaint either. Life is too short and time is one of the assest you cannot retrieve, no matter how hard you try.
djsfantasi
Joined Apr 11, 2010
9,237
I just ran into this problem where I was helping a friend out. If any XP users also are using Microsoft Security Essentials, note that it is no longer supported and no new downloads are available.
This can result in XP hanging! Security Essentials attempts to run, but it's database is no longer available. Windows appears to be running, but no programs can be started (including Windows Explorer and Task Manager). It becomes totally unresponsive.
The fix is to start in Safe Mode and disable the MSE service. Then, restart Windows normally. Sorry, I don't have XP here and don't remember the actual service name.
THE_RB
Joined Feb 11, 2008
5,438
So why didn't I get an invite to the funeral?
I love funerals.
:D
No funeral yet, it's still in its "zombie undead stagger", not realising it is dead while it jerks about getting shot. Sooner or later that good head shot will end it. ;)
Getting out while the going is good is the mark of a smart man, and he's definitely that. But we're talking about the evil empire, not the founding emperor.
Most of the people I know are using old Windows, that was bought many years ago, even a decade ago. That's not good for a operating system company. And when they buy new computers people often buy direct fron Ebay/China etc, where the bundled operating system Win7/Win8 is probably not giving any money to M$ either, for obvious reasons.
And those not buying imported chinese cracked computers are probably buying Linux/Android devices etc. None of this scenario is good for M$.
I think the days when almost everyone's computer was subservient to one software company are almost over. It's been a dark part of history where almost everyone had no choice but to bow down to one company's anti-social, conspiring regime.
Wendy
Joined Mar 24, 2008
23,809
Problem is, the programs other people have to write have to run on something. Win8 is a disaster, true. But Win7 is pretty good, and MS has a reputation for alternating lemons with winners.
With 90% of the market share still belonging to M$ I would not hold your breath for a major change.
Again, I'm rooting for Linux, but I also looked up the stats.
Windows 8.1 update
I have used win 7 and XP in the past, but hate xp now.
Don't understand all the win 8 hate, mine never crashes, with usb devices or anything. If you don't like metro, disable it as i have done, Also try a program like startisback. Mine behaves and looks just like win 7 minus aero. It is stable and fast.
studiot
Joined Nov 9, 2007
4,998
Well I have found Windows 2000 to be the least troublesome of the lot.
The W2K based DVD recorder I built nearly 15 years ago is still running strong, has never had a virus and only falls over occasionally when MathCad or Corel gets too much for it.
Metalmann
Joined Dec 8, 2012
703
Windows 8.1 update
"Failed data set"
That is what I got when I tried to install startisback.
Did you have any problems with the installation, TL?:confused:
