What normally goes bad on an electric blanket controller?
designer85
Joined Jan 27, 2016
5
I've got a Sealy (beddeford) queen sized electric blanket that comes with 2 controllers. Model TC1583. They are the digital ones that go from 1-9 and both will not turn on. They've been working fine since we got them about 5-6 years ago. When we no longer need the blanket we put it away, but the controllers have stayed plugged in, but turned off this whole time. This year they will not turn on at all. I'm a bit of a newbie, but I'm fairly familiar to the inside of electronics.
I'd just like to know what is the most common thing to fail in something like this so I'll know what to check. Everything looks ok from a visual check. I've got a multimeter, but I'm not exactly sure what to check and what will tell me if something is good or bad. Any help is appreciated. I'm attaching what the controller looks like below from an image I found online.
Alec_t
Joined Sep 17, 2013
15,156
Welcome to AAC!
Is the control intended to 'remember' its last setting? If so, there may be an internal battery which has died.
Kermit2
Joined Feb 5, 2010
4,159
If left plugged in an outlet for half the year, then I would suspect power surge damage on the input side of the circuit.
18,167
Disconnect them from power for a while (10 seconds or more) and plug them into a known-good wall socket. Make sure they are also connected to the blanket. Check for a battery as noted.
This will rule out the obvious stuff that you need to do before thinking about opening one up. Are they independently powered, or one from the other? It would be odd for both to fail. There could be an internal fuse that has blown and taken them both out.
designer85
Joined Jan 27, 2016
5
Welcome to AAC!
Thanks for the welcome! I honestly can't remember, but I don't see a battery. I'll post a photo of the inside in a minute.
designer85
Joined Jan 27, 2016
5
They are independently powered. They are two identical units and each has its own power cord. I do see a fuse on the board, but they both look ok.
designer85
Joined Jan 27, 2016
5
Make sure that you are plugged in all the way to the blanket part? Check to see if there is DC voltage on C3.
I'm getting 2.64v on C3. The controller would normally work without being plugged into the blanket. As long as it was plugged into the outlet it would turn on and you could adjust the settings. Now it's like its completely dead.
18,167
Check for continuity across the fuse, just to be sure. It's easy to miss the break sometimes. Then check the big white thermal fuse labeled THF on the board.
SLK001
Joined Nov 29, 2011
1,549
It may be a trick of the light, but is the top of that big C2 cap bulging?
No. It's the light. The light is coming from the top. The "pre-stessing" indents are still down and mostly straight across, as seen by looking at the reflected light.
18,167
If you want a quick fix attempt, just replace all the electrolytic caps. It won't cost much, and there's a distinct possibility you have bad caps. They don't need to burst to go bad. They "dry out" with age.
