a dc circuit. starting with a 680uf 450v capacitor charged to 430vdc. positive to an electromagnet coil. add a fly back diode. then to a mosfet then to ground of capacitor. n555 chip astable mode approximately 3ms pulse. run signal thru an octocoupler(k814p) to get to needed gate voltage. latest attempt was 47n60f. previously tried 70tps12 thy resistor. works but commutation is a pain. solid sate relays are expensive and large at that power level. if i must next step is to try scr but same issue with having to add a commutation circuit. can anyone recommend a mosfet that will work? what gate voltage and amperage to use?
