What kind of LEDs are these?
GRNDPNDR
Joined Mar 1, 2012
545
That works fine, much better than parallel, and offers decent efficiency. The down side is what you've noted - it's like a string of christmas lights. And not all LEDs will light on 12V with 4 in series. It sounds like yours do, so you should be all set.
I was just slightly mistaken here. They're wired in series so that they can use a minimal resistor as the LEDs in series require 13.2V, and typically an automotive system never drops below 13V, even if it was down to 12V that would only be when the engine isn't running and the battery is dead/dying anyway.
So realistically there shouldn't be any issue with them not being bright enough or not lit at all. It's a really minor light anyway but it's one of those added little touches that makes someone say "wow, you went all in" plus the factory green LEDs look stupid with the rest of the lighting being blue.
That will work, but so would 270, 330, 390 or 470Ω. It just depends how bright you want them. You might be able to go as low as 100Ω and still be in spec for your LEDs but don't try that without working up to it. Chances are it'll be plenty bright with any of those other values. The higher the value resistor you use, the less likely you are to age the LEDs with voltage spikes.
Brightness shouldn't be an issue, as stated above. The factory lights in these spots are super dim, and can really only been seen when it's fully night time. The super bright leds are actually "too bright" technically, or more specifically brighter than needed for a switch that you will generally only have have to use once or twice in a life time (The mirror adjustment switch)
So I'll stick with a 220 ohm. It's more important that they don't burn out when running at 15V than it is for them to be stupid bright at 12V
GRNDPNDR
Joined Mar 1, 2012
545
I got the 220ohm resistor installed and I have to say it's working perfectly.
At 9VDC the lights are about as bright as the factory "regular green leds", at 12VDC they're plenty bright, in fact ALMOST too bright. and when running at 15VDC they're as bright as they can be.
so I guess I could use a higher value resistor, because honestly if I was down at 11V I'd rather see the lights being off, because at that point the battery is considered fully and completely dead.
at any rate it's working great, my only concern is the lifespan of the bulbs running at 14.5V (typical automotive voltage)
28,645
LED devices running within the specified limits will last a very long time, possibly indefinitely. I am not aware of any time dependent failure modes, in fact. If you changed the resistor from 220 ohms to 270 ohms they will definitely outlast the application.
