What kind of drill is this?
spinnaker
Joined Oct 29, 2009
7,830
Nice saw. I have a full sized one. It has saved me a number of times. But often it is just too large for the job.
Another tool I was looking at, was a right angle drill. Wish I had one a number of times.
30,816
While on the subject of useful tools, one I get a lot of use out of is a Greenlee hole punch set, you can get a wide variation of punch shapes, holes, both round and square, I even have a couple left over from the old 25pin and 9pin D style COM sockets.
Nice for panel PB's.
DrewStupid
Joined Nov 28, 2018
64
The amount I use (Perspex sheet), usually with a band saw.
Yes... it cloggs up ! Lower speed ?
@DrewStupid Same answer. Unfortunately, I copied and pasted your original spelling into Google. After a page of embarrassment, the correct term came up. Now, it will be weeks before I stop getting pop-ups related to the original spelling.:(
Perspex was just another word I had to translate when living in N.A.;)
In any case. How do cut it. eg 4mm.
30,816
Usually high speed causes melting and clogging, I converted mine to variable speed for different materials.
I suppose an alternative is a variable speed portable jig saw set up on a make-shift table, improvisation is the necessity of invention!
jpanhalt
Joined Jan 18, 2008
11,087
You can use a saw. I prefer carbide cutting edges. Water helps a lot. You can also scribe and break it like glass. That works great up to about 6 mm. For drilling, you can buy special drills or modify your own. The term I learned is "dubbing" off the tip. Basically, you grind a flat on the cutting edge so it scrapes rather than digs in.
18,169
I once started a thread on well-designed tools (and other stuff). This looks like a good candidate.
JohnInTX
Joined Jun 26, 2012
4,787
FWIW For special Perspex / Plexiglas cutters and drills check out Avery Tools on the Hicks airport in Fort Worth or aviation parts companies like Wicks or Aircraft Spruce and Supply. Kitplane builders use them for canopies etc.
cmartinez
Joined Jan 17, 2007
8,862
That's an excellent tool... a little expensive, though. But extremely effective.
shortbus
Joined Sep 30, 2009
10,049
Already had a set that went to 2" pipe/conduit. But when my neighbor passed away his daughter gave me his set, goes up to 4" conduit and came with the ratchet driver. He was an electrician in a car plant. It is similar to this one - https://www.amazon.com/Greenlee-1906SB-Slug-Buster-Ratchet-Conduit/dp/B001UKB60C
30,816
Yeah, I have the Conduit set also, I have been tempted over the years to convert it to the Hydraulic version, but never got around to it!:(
