What kind of drill is this?
spinnaker
Joined Oct 29, 2009
7,830
Was browsing the tools at the local Lowes and came across this. What kind of drill is this? I would assume it is for drilling at angles? But I find it a bit odd that ut would bot have an adjustable bracket so that you can drill at precise angles.
jpanhalt
Joined Jan 18, 2008
11,087
If you are sure it is a drill? Can you show the chuck?
It might be configured for drilling in close quarters, such as floor joists to pass cable. It could also be something that uses a "rotozip" which is a type of drill bit that also cuts on its sides. You can use them to make cutouts. So far as I know, all drills will cut at an angle if started that way and even unintentionally if started normal to the surface.
spinnaker
Joined Oct 29, 2009
7,830
Wait maybe it is it??? It sure has a odd attachment for the blade. Looks like a chuck. I should have look at the end of "the chuck" then it would have been obvious it is not a drill.
Maybe a quick blade change attachment?
DrewStupid
Joined Nov 28, 2018
64
I see a spring . Up and down. Type of jigsaw .Very strange ! Mayby that could solve my problem of cutting perspex !
