The amount I use (Perspex sheet), usually with a band saw.By the way.. how do you cut persex ? Don't have a laser.
They don't even name it in the manual!Hello,
Have a look at its manual.
Bertus
How about an oscillating saw? I’ve never figured out how to use one, but the one I had access to had a chuck similar to a drill chuck, only different.
https://www.homedepot.com/b/Tools-Power-Tools-Power-Multi-Tools-Oscillating-Tools/N-5yc1vZc2b2
Perspex was just another word I had to translate when living in N.A.Persex in the context of this Forum, is an extruded acrylic plastic. Look up cutting acrylic plastic/Plexiglas.
Yes... it cloggs up ! Lower speed ?The amount I use (Perspex sheet), usually with a band saw.
Max.
@DrewStupid Same answer. Unfortunately, I copied and pasted your original spelling into Google. After a page of embarrassment, the correct term came up. Now, it will be weeks before I stop getting pop-ups related to the original spelling.![]()
In any case. How do cut it. eg 4mm.Perspex was just another word I had to translate when living in N.A.
Max.
I once started a thread on well-designed tools (and other stuff). This looks like a good candidate.While on the subject of useful tools, one I get a lot of use out of is a Greenlee hole punch set, you can get a wide variation of punch shapes, holes, both round and square, I even have a couple left over from the old 25pin and 9pin D style COM sockets.
Nice for panel PB's.
Max.
That's an excellent tool... a little expensive, though. But extremely effective.While on the subject of useful tools, one I get a lot of use out of is a Greenlee hole punch set, you can get a wide variation of punch shapes, holes, both round and square, I even have a couple left over from the old 25pin and 9pin D style COM sockets.
Max.
Hole punches were common before circuit boards. We had chassis.
Already had a set that went to 2" pipe/conduit. But when my neighbor passed away his daughter gave me his set, goes up to 4" conduit and came with the ratchet driver. He was an electrician in a car plant. It is similar to this one - https://www.amazon.com/Greenlee-1906SB-Slug-Buster-Ratchet-Conduit/dp/B001UKB60CWhile on the subject of useful tools, one I get a lot of use out of is a Greenlee hole punch set, you can get a wide variation of punch shapes, holes, both round and square, I even have a couple left over from the old 25pin and 9pin D style COM sockets.
Max.
Yeah, I have the Conduit set also, I have been tempted over the years to convert it to the Hydraulic version, but never got around to it!Already had a set that went to 2" pipe/conduit. But when my neighbor passed away his daughter gave me his set, goes up to 4" conduit and came with the ratchet driver.
