Actually i have seen some but eventually in the later days these stuff doesn't work as in its first use not sure why..That would be my advice to you. Good luck.
And by the way i found the modem has a signal memory...once the memory is low it will keep low whenever you don't restart...Once it is restarted then it will comes back to normal. It's quite interesting all these finding ...and intriguing to understand.
