What is wrong with my single supply Opamp
hoyyoth
Joined Mar 21, 2020
531
I am designing a single supply amplifier using Lm358. My input is a sine wave with a DC offset of 2V and an AC imposed on that with 0.2V peak.The gain of the amplifier is 11.
The expected output at the amplifier is 2.2V (4.4V peak to peak) . But I am getting only 323mV Peak to Peak.
My circuit is given below.
Please find the attached schematic and spice model of LM358.
Please let me know where I went wrong
hoyyoth
Joined Mar 21, 2020
531
Thank you.
Total impedance of R1 and C2 to be 100 Ohm for a gain of 11.
Need to fine tune the value of C2 and R1 such that the total impedance sholud be 100 Ohm.
Please correct me if I am wrong.
I choose C2 such that the filter formed by C2 and R1 needs to pass 50Hz
What can be done if the source frequency is changing
hoyyoth
Joined Mar 21, 2020
531
Hi Eric,
My intention is to amplify only the AC content of the signal.I did not want to amplify the DC content.
Here the gain is 11.
The peak to peak amplitude of AC component is 0.4V .
The expected output voltage is 4.4V.(11*0.4).
But getting a value of 2.35V
sghioto
Joined Dec 31, 2017
8,756
I figured the same losses but with the circuit below the gain was actually nine
I breadboarded that circuit using this configuration.
C2 has an impedance of 470 ohms at 100hz so the actual gain is 9+1 = 10.
There was a 0.2 volt loss across C1 on the output resulting in a total gain of 9
