What is this resistor
Papabravo
Joined Feb 24, 2006
22,082
Hi there. Probably a simple question for most. but that is this resistor in the photograph and whats it for? is it really needed.
I want to buy this component of http://farnell.com but not sure what to get
Thanks in advance for any help given
It appears to be a bleeder resistor. It is there to discharge that large power supply capacitor, which could deliver a fatal shock after the supply is turned off.
BR-549
Joined Sep 22, 2013
4,931
Do you need another resistor like the one shown? What's wrong with that one? Looks good.
I don't know what it's used for.....but til I did, I would not replace it with a wire wound.
27,504
What does the resistor do? That depends a whole lot on what the device it is connected to is. If it is a power supply as some presume, then it sets a minimum current that the supply will bve delivering. Some types of regulator circuits need to have a load connected at all times to function properly.
It appears that it may have been soldered to the end of the red wire's terminal, so it may have been installed for a reason.. When installing the replacement fist be sure that the item is unplugged, not just switched off. AND, leave the resistor leads longer so that there is some ability to flex without the next resistor breaking as well.
27,504
Bleed down resistor!
Max.
What a "bleed down resistor" does is to draw current to discharge the capacitors in a power supply. This function is mostly useful in those power supplies that have larger output capacitors and the voltage control does not cause those capacitors to discharge when the voltage setting is reduced, and whatever load current is drawn does not discharge them very rapidly. In power supplies where the output voltage is high enough to be a shock hazard they serve also to drain the voltage when the supply is switched off, to reduce the shock hazard a bit.
Ya’akov
Joined Jan 27, 2019
10,235
From the photo it is almost certainly already wirewound. Everything about it looks like a bleeder. Even if it is not, such a large power resistor is extremely unlikely to be in an inductively sensitive circuit.
