What is this 8-pin connector called?
hertugen
Joined Jun 20, 2019
Perfect, much appreciated. Sorry for being a bit ambiguous - I need a female version to mount on a PCB, so that I can just plug the display onto it.
ScottWang
Joined Aug 23, 2012
7,509
I think you need a male version to mount on a PCB, not a female, the needle side is male.
What's the connector of the display? (Male, Female)
hertugen
Joined Jun 20, 2019
Thank you, but BobTPH is right - the PCB should preferably have a female, angled connector mounted, so that the e-ink display slides right in as a daughterboard. I can use the cable, also shown on the picture, but I think that a PCB-mounted connector is just a more elegant solution and will save space inside a cramped cabinet as well.
