What is the value & voltage ratings of this capacitor
Status
Not open for further replies.
Vindhyachal Takniki
Joined Nov 3, 2014
598
1. Attached find a pic of a board. This is capacitive supply board & two capacitor in series are used. The boards works upto 440V.
2. What is capacitance & voltage rating of this capacitor.
Is cap = 550uF
& voltage rating=??
3. H684K C
550MFF4
Not sure if its C in first line end.
hp1729
Joined Nov 23, 2015
2,304
Is cap = 550uF
& voltage rating=??
3. H684K C
550MFF4
I would say 0.68 uF (684 = 680,000 pF), 550 V
bertus
Joined Apr 5, 2008
23,025
That's interesting. 550 nF would not be a standard value. 0.68 uF would be. That would be an unusually large capacitor for 550 nF.
550 Volts is also not a standard value, I would expect to find a 630 Volts type.
Bertus
ian field
Joined Oct 27, 2012
6,536
Is cap = 550uF
& voltage rating=??
3. H684K C
550MFF4
The 684K corresponds to the preferred value; 680000pF (or 680nF) and the K is a predictable tolerance code.
It doesn't look big enough for 550V, and that would be a peculiar voltage rating unless its some sort of code.
ian field
Joined Oct 27, 2012
6,536
Vindhyachal Takniki
Joined Nov 3, 2014
598
Thanks for your reply.
I have to make a capacitive supply from 440Vac to 9vdc & then regulator 7805.
Will make & see the results. Tested using these capacitors it is working fine.
But I will connect two 2.2uF,400V in series to be used for this since current requirement is bit more, cap as in attaced pic. SO that end capacitance is 1.1uF/800V.
Though They are not safe since they are not X2 type. But I have seen them in so many boards, none of them had any problem due to capacitor or capacitor every busted.
1. Are these two capacitor in series can withstand 440Vac. Since combined voltage value will be 800V. In ac 440Vac peak will be = 440*(2^0.5) = 622Vac. So I think I am well within limits?
Theoretically for 800V max ac can be = 800V/(2^0.5) = 565Vac.
2. What is voltage variation in these capacitors? is it +-10%?
3. Which fuse value should be used in this? Max ac load comes out to 150mA. So I am placing 1A fuse.
4. What is the MOV selection criteria for this.
Edit: Image link https://drive.google.com/open?id=0B-jbeBk3wfkWNWV5cmhWenlRbm8
There was problem in image uploading here
ScottWang
Joined Aug 23, 2012
7,509
This thread will be closed, because the contents were violated with the UA(User Agreement).
6. Restricted topics. The following topics are regularly raised however are considered "off-topic" at all times and will result in Your thread being closed without question:
* Any kind of over-unity devices and systems
* Devices designed to electrocute or shock another person
* LEDs to mains
* Any kind of jammers (ie - Phone jammers)
* Rail guns and high-energy projectile devices
* Transformer-less power supplies
If You come across a thread or post discussing any of the above topics please report the thread so We can close, and if necessary remove, the offending thread/posts.
User Agreement:
http://www.allaboutcircuits.com/user-agreement/
Status
