What is the signal frequency range of a particular oscilloscope?
PDK
Joined Mar 7, 2017
Forgive me but I am a little out of my depth here. I have been asked a question about and hand held oscilloscope and my own knowledge extends only to a multimeter at best! I have been left minding the shop for a couple of days and have had an inquiry into whether a certain oscilloscope would measure a 125 kHz signal. My current understanding is that the bandwidth and sampling rate indicate the scopes capabilities in this regard. However I am not sure if a scope has a lower limitation when it comes to frequency? For the sake of clarity I have reproduced the scope's specifications below. I would be grateful of any help.
40 MHz sampling rate
12 MHz analog bandwith
0.1 mV sensitivity
5mV to 20V/div in 12 steps
50ns to 1 hour/div time base in 34 steps
ultra fast full auto set up option
adjustable trigger level
X and Y position signal shift
DVM readout
audio, power calculation (rms and peak)
dBm, dBV, DC, rms ... measurements
signal markers for voltage and time
frequency readout (through markers)
recorder function (roll mode)
signal storage (2 memories)
high-resolution LCD 192x112 pixels
LCD backlight
galvanically separated USB output for PC
data or bitmap download to PC
different screen modes
normal screen view
wide screen with DVM
normal screen with large DVM
wide screen with large DVM
USB PC Connection real-time and screen capture
in the box:
worldwide charging adaptor
insulated measurement probe x1 / x10: PROBE60S
USB cable
Handheld Personal Scope
PDK
Joined Mar 7, 2017
Bandwidth 12Mhz. Shouldn't be a problem at 125kHZ. Scopes will measure to DC also. Just ensure DC coupling is on.
Thanks for the reply. Just for my own future enlightenment. What determines the frequency range any oscilloscope can deal with?
#12
Joined Nov 30, 2010
18,224
12 MHz bandwidth means zero to 12 MHz.
I don't think any scope exists that can't do 1 MHz. You can't miss while trying to work with 125 KHz.
The way it's designed and built.
Kind of like, "What determines the speed a car can go?"
dl324
Joined Mar 30, 2015
18,521
Kindly tell us what kind of signal. Square wave, sine wave, triangle wave, ??? If you're doing audio, a few MHz bandwidth would be more than sufficient.
You made a typo on the sampling rate. It's in Mega Samples Per Second, not Mega Hertz.
For the sake of clarity, you obfuscated the meaningful parameters by including many that have no bearing on bandwidth.
I think I know what they did. One issue is the Nyquest Creiteria where the sampling rate has to be 2x the sine wave signal of interest. Square waves introduce all sorts of weierdness, because technically a square wave requires infinite bandwidth. Fourier theory says It's composed of the sum of odd harmonic sin waves.
Analog bandwidth is normally cited as the -3db point at when the signal drops to 70.7% of the lowest frequency.
The analog scope may have more "useable" bandwith, but the amplitude isn't accurate above that -3 db point.
I might expect this to be equivalent of a 20 mHz scope, but I'll bet the accuracy specifications are is rated to 12 Mhz.
Here http://www.eetimes.com/document.asp?doc_id=1276244 is a little blurb.
Here http://cp.literature.agilent.com/litweb/pdf/5989-5733EN.pdf is a more complex note.
