- Joined Jan 23, 2018
- 28,636
The graph shown is correct, but it only shows half of the story, which is the high to low output transition. In many digital circuits the output versus input trace for output low to high does not lie on the same line. That means that as the Vin drops the Vout plot would not be the same as for the plot with Vin rising.. And, making things more interesting, the difference may change a bit with temperature or supply voltage, as well as with the different manufacturers. That last has caused problems for me with one production run a few years ago.Doing some simulation output clearly non linear, so no small signal
approaches will work for analysis.
The output duty cycle not being square is fact gates threshold not
exactly Vdd/2. This is transfer plot of a CMOS gate -
Regards, Dana.
