what is the frequency of oscillator circuit
Jagdish23
Joined Apr 3, 2014
I am having trouble in finding the actual frequency formula for the attached image.
As per me, the frequency should be (1/6RC)
I will be helpful if the derivation of the same is explained.
danadak
Joined Mar 10, 2018
4,057
Think in terms of phase angle, to get osc loop phase must be n x 360, inverter elements
contribute 180, so in this example they contribute 540, so you need how much phase out
of the RC's ?
Then back into what freq this occurs at.
Regards, Dana.
Jagdish23
Joined Apr 3, 2014
of the RC's ?
Regards, Dana.
Hi Dana, thanks for the hint.
I too used the same hint and tried to solve the equation. but I get w(omega)=(1/RC*sqrt(6)) as the answer.
But for the same circuit, the answer given as is 1/(3.3RC). So the doubt generated in my mind to consider which answer as the correct one!!!
Regards,
Jagdish
jpanhalt
Joined Jan 18, 2008
11,087
Try something like this:
Source: Fairchild AN118 (1974, no longer online). Be sure to have an odd number of gates. Use only one capacitor.
28,488
The symbol shows them as inverters, the frequency will also depend on the threshold voltages for switching, and that will usually depend on the temperature, and the logic family.
28,488
It is not the propagation delay that affects the frequency, it is the shifting of the voltages at which the gate changes state. And the change in Vhl may not be the same as the change in Vlh. And the switching point determines how far on the RC time constant curve the voltage must go for the thing to change, thus affecting the frequency in a non-linear manner. Of course, if you use perfect gates in a simple simulator this is not a problem. Real gates, such as cheap CD4001 NORs, with both inputs tied, are a different story.
danadak
Joined Mar 10, 2018
4,057
Of course the prop delay affects frequency. In fact in semiconductor processing,
using 3 inverters in series feedback, on wafer test site, the freq is measured (and
largely dependent on Tpd, Vdd) to evaluate the Fmax of a process.
When you look at transfer curves of the inverter there is a substantial "linear"
region over which small signal behavior exists to create an osc.
Is there no relation to switching levels, no, Vdd very much impacts Vth, and G of
the inverter. But the osc can and will operate around the bias point which Vth is
very much involved. Main contribution to osc freq however is R and C, available
current and capacitance. Tpd directly impacted, Vth not so much.
The CMOS inverter structure is largely a linear G element. one with a RC lowpass
behavior. Switching speed characterized by available current to charge C, usually
expressed as prop delay.
http://bwrcs.eecs.berkeley.edu/Classes/icdesign/ee141_f01/Notes/chapter5.pdf
https://www.egr.msu.edu/classes/ece410/mason/files/Ch7.pdf
Regards, Dana.
28,488
Regards, Dana.
The propagation delay is very small relative to the typical frequency of a common phase shift oscillator, and so while it will certainly have some effect it would not be very large at 1 Kilohertz. The variation in switch point voltage will have a larger effect, and with cheap CMOS that will matter. And in the really cheap consumer products, using a 4001 quad nor as a set of inverters is fairly common.
danadak
Joined Mar 10, 2018
4,057
I concur.
I am in process of trying out a spice sim to see what happens.
My thought is Vth variation is like Tpd change, a small result. That
its RC changes that dominate. Hopefully the sim will give us an idea.
Regards, Dana.
The Electrician
Joined Oct 9, 2007
2,986
This formula only applies to the circuit of Fig. 2 of the referenced paper where the CR phase shifting pairs are separated from one another by unity gain buffers.
Without the buffers, as in Fig. 3, the formula no longer applies. As the author says just in front of Fig. 3: "If the RC cells were isolated from each other, the phase shift per cell would be 60º. However, not being it the case, we need to perform a detailed analysis considering loading effects. "
28,488
In the initial posting there were indeed 3 separate cells,and probably the assumption that all three were identical, and with "perfect" inverters. What we find in the real world is that the inverters are not perfect and the components are seldom identical. The voltage to switch from low out to high out is not the same as the voltage to switch from high out to low out, and the current that the devices can sink is more that what they can source. And the voltages change with temperature, but not by the same amount. So running the circuit on a simulator will require specifying a whole lot of parameters, or picking a good part for the inverters. The circuit will run quite differently with a CD4049 then with a CD4009, OR A 74C04. and using a really cheap CD4001 with inputs tied will be different yet. Every part of the circuit will have an effect. As the difference between the two switch points increases the frequency will drop, likewise, as the current that the gate can source drops, so will the frequency.
danadak
Joined Mar 10, 2018
4,057
Assuming F is << Tpd, probably formula still pretty good. Why, because the other
180 has to come out of the 3 RC networks. To a first order. Clearly this design is
a mix of large signal, small signal, and non linear dynamics. It would be instructive
to look at actual spectrum to see how much impact the non linearities have.
Unity gain issue, yes true to a point. Again how impactfull are all these other factors.
We can surmise that until we actually make some measurements that all this is speculative.
But I know one constraint, the 3 RC have to provide 180 degrees if we find spectrum
close to sinusoidal.
I am away from primary lab so spectrum analysis is marginal, maybe FFT will be
enough.
Yes, but when we characterized parts for process standards we often found fairly
good matching in Vth on single die, die to die on wafer, but central to edge
of wafer where dopant concentrations varied over that distance significantly Vth
quite sloppy.
Yes, the sim will need a lot of trial tweaking to see what contributes large errors
vs rats nuts sized issues. The Pchan mobility vs Nchan I concur issue. The structure
inherently unbalanced.
As far as the transfer characteristic H-L vs L-H, I only see one trajectory in published
CMOS graphic transfer characteristic. I must be missing something here ?
The whole idea of making an osc this way is filled with part and passive
tolerance, T, and V issues. But would be interesting just what and how
much do each of these factors contribute, and does the argument stand
each RC, if matched, do have to contribute 60 degrees.....
Fun stuff....
Regards, Dana.
Jony130
Joined Feb 17, 2009
5,601
I don't think so.
As you can see for R = 10kΩ and C = 1nF; Vdd = 5V the frequnct of oscilation is arond 28Khz.
So the formula for RC Phase-Shift Oscillator won't work in this case.
28,488
I don't think so.
Jony, I am wondering about where in the circuit the waveforms shown are taken from. Or is it a simulation? I am especially puzzled by the lack of squareness of what should be a square wave. Please let us know which circuit, or variation, this is from. AND where the measurement points are located.
danadak
Joined Mar 10, 2018
4,057
The measurement points shown are the output of the inverter, and the input to the inverter
after RC network. I think Jony posted a scope capture for a bench prototype...
Regards, Dana.
28,488
The square wave does not look as square as I would anticipate for the points monitored. I had guessed that is what they were, but the rounded corners don't seem right. And you can see that while the top of the ramp wave is about in the center, the bottom is not, thus showing that there is a difference in the high and low switching points on the gate. With this being the 3-RC version it shows that using the RC time constant to find frequency is a bit more complicated, since each one is a third of the cycle time, and the rise is faster than the fall.
danadak
Joined Mar 10, 2018
4,057
Doing some simulation output clearly non linear, so no small signal
approaches will work for analysis.
The output duty cycle not being square is fact gates threshold not
exactly Vdd/2. This is transfer plot of a CMOS gate -
Regards, Dana.
