What is the circuit diagram equivalent to a resistance meter?
StuckStudent123
Joined Sep 23, 2016
23
If a voltmeter can be represented as a very large resistance and an ammeter can be represented as a very low resistance then what is the equivalent of a multi-meter on a resistance setting? I'm asking because I'm trying to make an oscillator circuit and currently the frequency is too low but I have noticed that when I measure the value of one of the resistors with a multi-meter when the resistor is still in the circuit, it gives me the frequency I want. I've tried changing the value of the resistor to a lower one (I thought maybe it would have been like resistors in parallel thus lowering the overall resistance) but this didn't help so I'm wondering how I can recreate the multi-meter's effect with components.
ericgibbs
Joined Jan 29, 2010
21,653
hi,
On Resistance measurement the probes apply a voltage across the resistance being tested.
You are injecting a voltage into your circuit.
E
Ian Rogers
Joined Dec 12, 2012
1,136
If you are slightly increasing the voltage by having the multimeter in circuit, you will need a higher value resistor ( if the resistor in question is common ground )...
This is an assumption... I'm assuming the resistor makes up a potential divider!
OBW0549
Joined Mar 2, 2015
3,565
Ummm... no, it's as @DickCappels said: the DVM injects a controlled constant current into the unknown resistance and measures the resulting voltage. If the meter were to apply a voltage and measure the resulting current, shorting the meter leads to verify zero or when checking continuity would be... problematic.
BillB3857
Joined Feb 28, 2009
2,573
It depends upon the type meter being used. Older (Simpson 260 for example) applied a voltage in series with the unknown resistance and measured the amount of current flowing through it. More modern meters use a constant current source and measure the voltage developed across the unknown resistance. Either type would tend to inject some voltage into an operating circuit. Try reversing the meter leads when you make your test. One way will probably raise the freq and the other way would probably lower the freq. Use a diode to see which lead is positive when checking resistance and that answer may answer your initial question.
WBahn
Joined Mar 31, 2012
33,361
First off, this isn't a useful way to make a resistance measurement -- whatever reading you get will almost certainly be impossible to extract any meaningful information from and if it seems like you can, then you are probably leading yourself down a rabbit hole.
But I understand that, validity of the measurement or not, you are trying to replicate it's impact on the circuit. As others have said, the equivalent circuit depends on the type of meter and even the brand and specific model as well as the range it is set on.
Do you have another meter handy? If so, then you can take a stab at measuring the DC parameters by noting the reading with it in the circuit and then removing it from the circuit and connect it to that value resistor and then use another meter, preferably a high-input impedance digital meter, to measure the voltage across the resistor. Then do the same with a resistor that is twice the size and again with half the size. See if these measurements agree with a model of the meter that consists of a voltage source in series with a resistor and, if so, figure out wha the values are -- we can help.
But this may not be sufficient -- in fact it probably won't be. Your oscillator is interacting with the meter at the frequency of oscillation and the appropriate model at that frequency might be very different from the DC model.
38,952
In summary, the answer to your question "What is the circuit diagram equivalent to a resistance meter?" for a typical digital multimeter, it's a constant-current source with a low voltage compliance limit in parallel with the meter input capacitance.
bertus
Joined Apr 5, 2008
23,041
When you look at the schematic of the simpson 260 multimeter, you will see R21 in the Ohms path.
This is used to "null" the ohms measurement. Just short the pins and set the 0 Ohms on the scale.
Also the scale will not be linear in the ohms range.
Bertus
