What is the best way to hook this IC up to a breadboard?
Andrew Armstrong
Joined Sep 7, 2016
24
If I have something like this :
http://uk.farnell.com/texas-instrum...Categories&searchView=table&iscrfnonsku=false -- Which I want to hookup to my breadboard...I assume I need something like this : http://uk.farnell.com/roth-elektron...p-28-0-65mm/dp/1426166?MER=bn_para_1TP_Echo_3
I cannot find a DIP package for the PCM1804. If I went for the SMD adapter, how do I actually connect the 1mm breakouts to the breadboard? Is there a special form of pin I would use? Or would a standard cable do fine?
Extra points for anybody capable of finding a PCM1804 in DIP Package so I don't have to do the adapter myself!
Andrew Armstrong
Joined Sep 7, 2016
24
Hi Eric - this looks far better. Is there any UK specific suppliers of this kind of board (i am not sure of its high level name) - ideally I would want to order from Farnell.
30,888
I used to purchase off of Newark, now Farnell and found them fairly expensive and costly P/P.
Futurlec supply internationally I believe and are reasonable in price.
NCSailor
Joined Jun 15, 2013
33
I believe all the Digikey links are to SOIC-28 to DIP adapters. I believe SSOP-28 is a much smaller footprint and lead spacing.
I did not verify this but wanted to make sure the OP checks before ordering and possible disappointment.
