Im trying to create a linear rail system to move my camera back and forth in a straight line. I will be making it a mobile unit i can take with me into the field and use it hand held. I want to use a small stepper motor like the nema 11 (could be another stepper i just dont want to have a motor with a diameter greater than about 53mm)
I will be using the Arduino Micro Pro 5v as the controller
I was planning to use the Sparkfun Easy stepper driver but come to find out it might not be able to run a stepper at higher rpm.
Also i came to find out it might need a separate power source with much higher voltage than the one i will need to use for the Arduino
So my question is what driver do i really need and how much voltage is going to be enough to accomplish my goal. It needs to be battery powered and i was hoping to connect the driver and controller to the same power source
