I looked this resistor up on digkey calculator and it don't have gold for third band. This is a 5 band resistor. Thanks anyone red red gold silver blue
Post a photo.I'm trying
Could it be an inductor?
Appears to be a resistor. 2.2ΩI guess I don't know if inductor or resistor.
The third band is definitely gold and can't find resistors that have gold for 3rd band. Been away to long.Appears to be a resistor.
Any markings on the Pcb, like L1, R1 etc...?I guess I don't know if inductor or resistor.
One end of the cap is going to common and the other end goes to earth ground.The picture shows a wide red ring on the left and the same distance between the five rings, so I will read the code from the left:
Red Red Gold Silver and Blue.
I have no explanation for the blue ring.
The thickness of the wires indicates a resistor.
So right now my best bet is: 2.2 Ω 10%
Is the mentioned component in series with the capacitor (68nF 275VAC X2) just behind it?
Looks more red, but can't really tell. The part is open so can't measure. ThanksAre you sure that it isn't orange, orange? It doesn't look damaged, so just hit it with a multimeter.
The supply is 24vac and the board is fed through this resistor or whatever it is.One end of the cap is going to common and the other end goes to earth ground.
Thanks Bertus, this has all the colors and in the correct place.Hello,
I think @wayneh is right.
2.2 Ω 10 % 10 PPM/°K
Have a look at this table:
Bertus
No markings on board.Any markings on the Pcb, like L1, R1 etc...?
Looks like 6.8 ohms, 2% 50ppm.
| Thread starter | Similar threads | Forum | Replies | Date |
| O | Are these miniature 0.3 F gold caps for real ? | General Electronics Chat | 6 | |
IC sockets, Gold or Tin? | General Electronics Chat | 10 | |
Looking for a gold medalist... | General Electronics Chat | 15 |
