What is more efficient to supply 3.3V??
35,299
Let us assume that you use a buck-boost converter to do either voltage conversion.
If each converter is 100% efficient then they are both the same in terms of energy efficiency.
jpanhalt
Joined Jan 18, 2008
11,087
I have used the NCP1402 in a boost configuration. It is really quite easy to do.
Sparkfun, Adafruit and others sell breakout boards for such items. The nice thing about such hobbyist oriented sites is that design information is often given. In my case, I used the SF design, which is basically just the datasheet, and modified it for my needs.
Buck/Boost:
https://www.sparkfun.com/products/15208
Boost (NCP1402):
https://www.sparkfun.com/products/10967
38,947
Depends upon the relative efficiency of the conversion.
Compare the efficiencies of a buck-converter and a boost-converter to see which is best.
