What is a 2w0.1 resistor
Damian4320
Joined May 1, 2020
8
Good day to all I hope everyone is well. So iam quite new to soldering and I ordered 2 diy voltmeter 7107 diy voltmeter from aliexpress but in both kits they haven't included a part called resistor 11 and its screened as R11 2w0.1 it as heat sinked tracks underneath and as 3 hole option can enyone tell me where to find a couple eny help would be appreciated please see picks is there a different name
jpanhalt
Joined Jan 18, 2008
11,087
Those low-value sense resistors (presumably precision) can be relatively expensive. A conventional supplier (e.g., Digikey, Mouser, Arrow, Newark, Farnell) may be cheaper in small lots and provide traceable devices.
Damian4320
Joined May 1, 2020
8
Good morning all I hope your well I have a question firstly I purchased 2 diy voltmeter projects iam stuck on a part as instructions are in Chinese characters il pop a pick in the part just says R6 RK but no value can enyone help please Thankyou for your time Damian
jpanhalt
Joined Jan 18, 2008
11,087
I believe R11 is the sense resistor. R6 looks like some sort of offset (meter zero, calibration?), particularly since it is in series as a voltage divider with a non-precision pot.
Damian4320
Joined May 1, 2020
8
Good morning all I hope your well I have a question firstly I purchased 2 diy voltmeter projects iam stuck on a part as instructions are in Chinese characters il pop a pick in the part just says R6 Rx but no value can enyone help please Thankyou for your time Damian
ps there is a trimmer pot coming of it
Damian4320
Joined May 1, 2020
8
ericgibbs
Joined Jan 29, 2010
21,654
hi,
Looking a the 7107 datasheet it shows the input resistor R5 as a 1meg Ohm, look at the attached datasheet. Figure #2
I would try Rx as a 1meg as a starting point
E
