What element should be J703?
UnnamedUser159
Joined May 3, 2016
501
I am seeing one LCD monitor - l1953s
The LED doesn`t light and begin to search in the service manual
CHECK J703
VOLTAGE
PIN5, PIN6 (5V)
I really dont see J703 in the schemes when watch at the power board
The only scheme with many pins on the back side i see is U301.
Alec_t
Joined Sep 17, 2013
15,171
"J" usually denotes a jumper (but I suppose a JFET would be another possibility, depending on the manufacturer's practice).
UnnamedUser159
Joined May 3, 2016
501
i think it`s about a IC but they have numbers different from 703. Probably it`s for u301 on the back side of the board
https://drive.google.com/file/d/0Bxome1ZSCRIaMGJDak9sV05CRWFsNVpQZ2hqaUJIZlE0aFRN/view?usp=sharing
https://drive.google.com/file/d/0Bxome1ZSCRIaUTdtYlJEMUtQeFBNbXNtQ1UwWGNrNEFSZUVJ/view?usp=sharing
http://cxem.net/ckfinder/userfiles/comments/53252_LG L17,1953S-xFS_EN.pdf
Could you explain me that
CHECK POWER BOARD,
AND FIND OUT A SHORT
POINT AS OPENING
EACH POWER LINE"
Thanks in advance
