What does this do to the signal ?
simmsdk
Joined Jul 16, 2011
2
Please look at the attached image for the schematic...
My question is:
What exactly does the schottky diode in parallel with the resister, and the capacitor do to the signal before it enters the last NAND.
What is it good for ?
praondevou
Joined Jul 9, 2011
2,942
When pin 3 of IC1A goes HIGH the capacitor C1 is being charged rapidly through diode D1.
When pin 3 of IC1A goes LOW the capacitor C1 is being slowly (more slowly than it was charged)
discharged through R1.
You create a delay on only one edge of the signal.
If you join the inputs of the left gate and feed a digital signal to it, then the rising edge of the
output signal IC1B pin 4 will be delayed, the falling edge remains almost unchanged.
hgmjr
Joined Jan 28, 2005
9,027
A better description of the effect of this circuit would be that the original pulse would be stretched so that the output is wider that the input.
hgmjr
