Does this circuit work if so explain how ...starting on when there pwm signal is high and when low
LesJones
Joined Jan 8, 2017
4,544
You will need to provide a lot more information to get an answer.
Draw the full schematic. Give full details of the drive signal. Give the part number of the mosfet. AND what do you require it to do ?
Les.
CarltonDranko
Joined Dec 30, 2020
22
Les.
High side gate drive.... Drain connected to input of 22.05V,source connected to a 12 V battery..... Switch should close when charging battery and open when the battery is full .
Ian0
Joined Aug 7, 2020
13,317
No it doesn't work.
The opto will drive the gate to 22.05V, the source will be about 3V lower than this (19V). Lots of current will flow and things will blow up.
