what do you think about my first simple circuit?
cmrincon
Joined Oct 25, 2017
40
Hi!
I'm a electronics student who is making a garage door opener. Im using a pre-made ask transmiter module with 50 ohm matching network, and a pic12f675. As power source im using a 12V LR23 battery and a LDO regulator. It has 2 buttons and only it is useful for 1 door..but with more free time i will add a receiver ask module and make a programmable garage door oppener.
I'm worried about leaving vcc pin of the TX module in open circuit...IO1 is at low level ALWAYS that IO3 is at high level. What do you think about this? will i have any problems?
If everything is ok i will start making the pcb tonight. Thanks
Regards.
Cesar
cmrincon
Joined Oct 25, 2017
40
i noticed one error. U1 has 4 pads, there are 2 missing in the schematic! 1 of them goes to ground and the other one to 12V
AlbertHall
Joined Jun 4, 2014
12,626
The battery life may not be too good. Even if the PIC is sleeping the battery will still be supplying power to the supply regulator.
cmrincon
Joined Oct 25, 2017
40
Hi!
Thanks you all! ;)
My idea was avoid using switches. About the regulator..i liked the MCP1702 LDO regulator, it's a great idea!
About the current consumption, i didn't notice that big mistake about the power regulator!
Finally im thinking about using a switch like DickCappels suggested, probably is the best solution.
