Belongs on a touch screen thermostat. Looks like its somewhere between the 4.5v battery supply and the rc/r supply. Maybe. Thats what im assuming any way. Pretty much still turns on and everything works except using rc/r to supply voltage to the stat. Only tried with 12v which it should run on 12-24 low volts and it wouldnt kick over but it would with 4.5v in the battery slots... i need to stat to use as a 12v switch so i need to figure out what this is. I want to say an ic surface mount but its not. It has 4 pins with a - and + at the top corners + being the right top. And below in the middle looks like 95... mmm thats where i get lost.... the U1 at tip of screw driver is the 4 pin slot. U will see the +. Adjacent to the right a cunthair. ANNNNYY help would be super appreciated. I wont give you this cheeseburger man but i sure will give mad props and extra kudos point for being amazing!
Ive spent more time today in front of the laptop screen Mod: Offensive comment removed.!
