what causes the "black corrosion" on the PCB?
kat_80
Joined Dec 14, 2017
hello
I have been battling this issue at my home electronic for quite a while. any electronic after using about a year or so start to show sign of black carbon deposit on any shinny part of the pcb. I thought it was the humidity in the basement that caused the issue but I checked and the humidity is only 35%. anyone have any idea what could cause this issue?
SLK001
Joined Nov 29, 2011
1,549
Do you smoke? Do you burn coal for fuel? Does your community burn coal for fuel? Is there a lot of soot in the air?
kat_80
Joined Dec 14, 2017
very interesting, never thought of that, there are very little soot in the air where I live and I don't smoke and I use natural gas furnace. however there is a natural gas processing plant about 15 miles away so H2S present in the air is a possibility and a OSB processing plant 5 miles away. I have never experience this problem on the home electronic on the main floor. I am suspecting that the air circulation is the basement is poor and therefore more soot in the air? do you think getting the HPA air purifier would solve this problem?
