power supply filter causes oscilations
yef smith
Joined Aug 2, 2020
1,485
Hello, At this manual time 2:20 they say that if Zout of the filyer will be at the same impedance as Zin then well have oscilations.
What is the logic behind it?
Is there a way to simulate it in ltspice?
Thanks.
kiroma
Joined Apr 30, 2014
307
Really nice, didn't know that. I always wondered how to tune a certain filter to not oscillate under dynamic loads, but there it is. It seems that it's possible to set a negative resistance in LTSpice. It remains for me to analyse such behaviors and verify the equations.
Thank you for that.
ronsimpson
Joined Oct 7, 2019
4,867
When SPICEing around the inductors might have zero ohms and the caps might have zero ESR. They will ring.
If you are looking at input filters in SPICE add the R to the L and Cs.
I sometimes I add damping resistors to the filter because the inductors have very low resistance.
38,929
Below is a way to simulate a simple negative impedance (current reduces with increasing voltage) in LTspice using the voltage-to-current source.
The G1 transconductance gain value (here 1) sets the value of the negative impedance.
38,929
1.impedance is a complex numberI think the meaning is negative resistance.
Yes, the circuit generates a negative impedance with no reactive component so it is a negative resistance.
how is the resistance is negative?
The current reduces as the voltage increases.
It's what the input to a switching-regulator does.
What is your definition of a negative resistance?
yef smith
Joined Aug 2, 2020
1,485
Hello Crutschow,my logic is R=V/I for example R=-5V/1A=-5Ohm
not reduction in value but the actual value, where am I wrong in the theory?
38,929
Your formula is just a reversal of the current through a normal resistance, which requires an amplifier.
Your logic is flawed.
Google AI says -- Negative resistance is an electrical characteristic where an increase in voltage across a device causes a decrease in current, creating a negative slope on a V-I graph.
That's what the simulated circuit does.
