Hello. I open a new thread because I think is a different topic. I have made a power supply with a resounded MOT to get up 12, 18, 24 and 38 volts making a conection every some turns and using a commutator to connect each one.
These voltages are after the filter. For filter I have used 20 X 2200 uf electrolitic capacitors. I'd like to put a resistor to discharge the capacitors once the power supply is off. I don't know if this is common, and how fast it should discharge. Any advice about resistance and power of the resistor?
And another question. When I use the conmutator with the power supply turned on, I suppose there will be no problem going up in the voltage, for example from 12 to 18, but Can I go down? I mean, lets say the conmutator is in 38 volts, and I turn it to 24. The voltage in the capacitors will be higher than the voltage in the brige rectifier. Is that a problem?
Thank you
Best regards
Thank you
Best regards
