What caused this corrosion on PCB?
jimstevens2022
Joined Jan 10, 2022
8
This pcb came from a vehicle interior with the board side seen in the attachment facing downwardly with some space below it. It was installed inside the vehicle. The car is about 2 years old.
Any idea what would have caused this corrosion on the transistor leads? The unit is not working and this would appear to be the cause. I cannot tell from visual inspection if any components failed.
Appreciate all the help I can get!
MaxHeadRoom
Joined Jul 18, 2013
30,858
It appears to me that something corrosive drained or dripped onto the board and ran down across a few components.
It appears to cover a small area in toto.
Ya’akov
Joined Jan 27, 2019
10,330
The white residue suggests water with a non-trivial mineral content. Is there any chance someone spilled some drinking water (from a bottle, etc.) in such a way it could get to the board?
MrSalts
Joined Apr 2, 2020
2,767
Coke, sweat, even condensation caused by the car filling with humid air on a cold part (cooled by the AC).
the white powder is likely tin oxide/hydroxide and the light blue powder is copper oxide/hydroxide. Other white oxides or carbonates may be present depending on the pH and cation.
what is the round component below the transistor? They appears to be a pressure sensor or gas sensor? Also, the blue powder around that indicates the corrosion may be deeper there as it is down to the copper (beyond the tin solder).
jimstevens2022
Joined Jan 10, 2022
8
Thanks for all the comments.
This module is mounted in the center console between the vehicle seats with the side of the pcb facing downwardly so it is not clear how liquid would have gotten onto that side of the pcb from a spill, but that is what I am trying to determine.
Could the corrosion be just from a couple instances of liquid exposure, as opposed to just humidity itself causing it? There is a second same transistor nearby (not shown in the picture) that has the same thing - heavy corrosion on the collector terminals.
That is the real issue I am trying to determine and get input on - was this caused by liquid spills that crept under the center console top and somehow got onto the bottom of the board or would it have to have been some longer term exposure such as from humidity over the course of a couple summers, or something else?
The reason it matters is because the dealer is asserting that it is customer (my) fault and not a warranty item. From my standpoint, I don't recall any instances of spills, but there might have been one or two. If it is my fault then I'm willing to pony up the large sum for the replacement part and labor, although even then I have to wonder about it being essentially a design flaw if a couple of spills could cause that underneath the console top. My problem is that I don't see or have any more evidence of it being my fault than either a manufacturing or design problem. Moreover, before they even looked at it they mentioned that these cars have that problem not infrequently.
- Jim
Ya’akov
Joined Jan 27, 2019
10,330
Honestly, it looks like water-on-the-PCB type damage and I would be surprised if humidity could cause it. On the other hand, how water got in to do that is a mystery. Is there any chance it came from under the car? (A leak in rainy conditions and puddles, for example)
jimstevens2022
Joined Jan 10, 2022
8
I don't think outside water could get in there, it is well up into the interior cabin with a solid underbody. The moon roof has never been left open in the elements. I know because the one time I tried to leave it open, just the air moving in and out through the top kept setting of the interior monitoring alarm!
MrSalts:
I don't think it's a sensor, I think it is a rubber seal of some sort - there are several, and this module is just for radio and display screen menu control. And actually, if you look at the first pic I posted, it looks as though that rubber seal is cracked. Maybe that's how the water got in there and is what accounts for all the mineralization around that seal.
I added a couple of pics below. First is the top of the module - a couple coaxial rotary knobs (function switch and volume pot), and a couple of micro-deflection switches. You can see a little water stain on the one switch, but again, how should that be able to get under the module and onto the downward facing side of the circuit board. Certainly possible to wick around the edge, per AlbertHall, but would that be enough in one or two instances to cause that corrosion all by itself?
Second picture is the full underside of the module with the two transistors that have corroded collector terminals.
jimstevens2022
Joined Jan 10, 2022
8
In my opinion, the manufacturer is being sloppy. The entire board should have been protected with conformal coating.
Yes, agreed, and exactly what I said to the service rep. But, OEMs and their dealers will never admit to design defects, they will just cover under warranty what they agree is a manufacturing defect.
The rep said he talked to his manager who said that the tech believed it had been exposed to water, which must mean a spill by the customer, and therefore is customer damage and the manufacturer wouldn't approve it if they sent it in for a warranty claim.
Probably my only relief will be either on the basis of "customer relations" or if I get the module from them and can fix it myself.
jimstevens2022
Joined Jan 10, 2022
8
Followup - the dealer checked with the OEM who said they don't consider it a manufacturing defect, but would cover the cost of the part and dropped the labor charge down so the total cost to me to a little under half of what they first quoted. Thanks for the assistance!
MrSalts
Joined Apr 2, 2020
2,767
Could you see which company made the part? It might be molded into the plastic or silk-screened on the PCB
