What Can a 12v AC Power Supply Be Used For?
Zohar
Joined Nov 19, 2015
70
Hi
I had a 2.0 set of Computer Speakers, that decided to die recently.
The AC Adapter is still working perfect tho.
It is a heavy (transformer based) Power Supply.
Its sticker says 12v 3A, and for years I was sure it is DC output..
But today when I measured it with with a Multimeter,
when the multimeter was on DC mode, the display showed 0v..
I thought it might be dead too, but then I decided to try to measure its output on AC mode,
and surprise, it says 14.4v..
So it is AC output apparently.
(the sticker on it does not mention AC or DC)
What can I do with it?
(and why did the speakers come with a 12v AC and not 12v DC Power Supply?)
Thank you
Zohar
Joined Nov 19, 2015
70
Thank you Max
If anyone can recall a situation in which he needed an AC output power supply, please write..
38,935
OK, seems that there will not be any use soon for this AC Output power supply..
(yet I might still keep it.. who knows If one day it might be needed)
You can always convert it to DC by adding a bridge rectifier, a filter capacitor, and a voltage regulator such as an LM317 (adjustable) or an LM7812 (fixed 12V).
#12
Joined Nov 30, 2010
18,224
I have at least 50 wall warts. They have many different voltages, AC and DC. Most of the time, I use them to hold down cardboard boxes and 2 pound coffee cans. When anybody needs one, I give it to them. This has saved speaker sets, telephone chargers, battery chargers, laptop computers, and several other things from going to the trash can.
Zohar
Joined Nov 19, 2015
70
Yeah I save Power Supplies too, but until ow they've all been DC Output..
OK then I will save it, after all it's 3A, not some low ampere one..
