What are these components
Abdel_Rahman
Joined Jul 19, 2016
42
That first component, I have not found it on "google" or in "all data sheet",:(:(
I want to know names of these two components and if there is any alternative to that first component.
mcgyvr
Joined Oct 15, 2009
5,394
2 parts on Bottom is a 33 ohm 5% wirewound resistor
Top could be a voltage regulator or many other things as that number doesn't seem to be industry standardized..
Reloadron
Joined Jan 15, 2015
7,889
The lower 2 look to be wire wound power resistors 33 Ohm 5% and maybe 15 to 20 watts. The upper component could be anything with a propitiatory part number, a transistor, MOSFET I have no idea. You don't mention what the board is used for and if you look at how the component is used in circuit it may help. Also looks like a cooked resistor below TR 10. I see McGyver already got things. :)
Ron
R!f@@
Joined Apr 2, 2009
10,004
SM61 part, I am not sure. Could be a MOSFET, a transistor, a triac or a regulator. I cannot get a hit for the datasheet.
The grey things are 33R wire wound resistors
DickCappels
Joined Aug 21, 2008
10,661
We can get an idea as to whether the MI61 is a bipolar transistor if you take some measurements with a digital voltmeter on the diode test setting.
With the positive probe (that should be the red one) on the leftmost leg (referencing the orientation in the photograph), measure to the middle and to the rightmost legs.
Put the black probe on the leftmost leg and take the two measurements again.
Then measure from the middle leg to the right-most leg in both directions.
Tell us the voltages (they will display as resistance readings) that you get for each measurement and we might be able to figure it out.
