What are these circuits?
dl324
Joined Mar 30, 2015
18,329
(a) diode is used as a half wave rectifier
(b) zener diode is used to set trip point of the comparator (open loop OP AMP)
David Waddell
Joined Dec 3, 2014
24
yeah I know what the components do, but i got this work back for corrections and the teacher wanted to know what type of circuit it is?
MikeML
5,444
Fig 1 is a DC power supply. I'll let you refine the description further.
Fig 2 is a battery voltage monitor. I'll let you figure out under what conditions the LED lights.
LDC3
Joined Apr 27, 2013
924
Im not sure, I was confused by what he wanted. The questions asked to explain the purpose of the component. I explained it and it was right but he wanted me to add what type of circuit it was.
The first one is a half wave rectifier (like dl324 said).
The LED in the second one will light if the battery can provide more than 6.2 volts. I suppose you can say that it indicates when a battery is sufficiently charged.
