It wouldnt do all its fancy stuff the like going one way then other?It's just a simple DC motor then, why all the complicated circuit board? Can you just connect the motor to the 3V supply?
Just my simple thinking here. Is it possible that the circuit board is similar to what is the circuit inside of an RC servo? I say that since that is how the winder is working, a partial rotation CW then CCW. And they in the winder just made a more robust, stronger drive train.It's just a simple DC motor then, why all the complicated circuit board?
Now i have a bit more info on this.Just my simple thinking here. Is it possible that the circuit board is similar to what is the circuit inside of an RC servo? I say that since that is how the winder is working, a partial rotation CW then CCW. And they in the winder just made a more robust, stronger drive train.
So just going back several posts, what is the likel cause that it doesn't work in its normal mode?
Now you're losinglol. Where would I measure and what measurement am I looking for?The four transistors will do the driving of the motor in a Bridge formation, so the Base terminals will be fed from the chip via resistors, follow the tracks to the chip and measure them.
Thank for that I will test tomorrow.The Green circle has the transistors and the Blue are the 2K resistors that feed them from the chip. If you can follow the Resistors to the chip pins and test for DC voltage.
Hi again,No. Check voltags at the motor, and on the chip pins.
Hi again all, i have done a drawing of something that resembles how i have tried to illustrate what i am doing.Hi again,
Just had a quick check, but will do a bit more in depth one later.
I have set the multi voltage power supply to 5v, not sure if it is a 12v board or not so set to 5v to check the chip. (it came with 12v supply but the battery compartment takes only 2 x 1.5v c size).
