Voltage vs Power Attenuators
dporay
Joined Oct 10, 2015
18
Since attenuators are specified as giving an attenuation in db, is there a difference in calculating the resistor values when dealing with voltage and power attenuators? This is being asked since db for voltage equals 20log Vo/Vi and the db for power equals 10log Po/Pi. If there is a difference, how does one know if the attenuator is specified for voltage or power? I would like to know the formulas for calculating the resistor values.
38,745
The are the same.
A dB is a dB.
The difference in calculation is because power is proportional to the square of the voltage.
So if an attenuator gives 10dB of attenuation it will reduce the output power by a factor of 10 and the voltage by a factor of the square-root of 10 = 3.162, assuming the load impedance matches the attenuation characteristic impedance.
