voltage source
djsfantasi
Joined Apr 11, 2010
9,237
Not gonna download anything from a third party site. Not gonna do it!
If you have a picture to share, upload it here and insert it into your post. Look at the buttons on the bottom of the place where you type your post.
MikeML
5,444
The current (which flows in the opposite direction of the electron drift) is the same in the top wire as in the bottom wire. That should answer your question. The current is the same everywhere in that circuit.
38,508
Electrons can't be created or destroyed (at least not easily) so those that that leave one terminal of the battery must be matched by the same number going into the other terminal.
sharanbr
Joined Apr 13, 2009
82
So, electrons exit the negative terminal of voltage source and then enter the positive terminal?
The only difference is what terminal can supply current and what terminal can sink.
Did I understand this correct?
38,508
Yes. The battery chemicals generate an EMF (the battery voltage) which pushes the electrons out the negative terminal and attracts them to the positive terminal.
The net battery charge does not change during this process.
