What are the types of voltage regulator circuits that can be used to regulate voltages in the range of 200 - 240 Volts? I need a circuit that will prevent the voltage from exceeding a value of about 210 volts.
I'm not sure if a simple clipper circuit will work in this instance. Is there a way to adapt one for this voltage range?
