So I plan to use an LM7805 to regulate 9V to 5V. The recommended decoupling values that are given in the datasheet are used in the simulation below.
Is there a calculation to work out the the required values for the decoupling capacitors? I imagine the loads current is needed, but I am not sure how to work it out. I have it simulated in multisim if it is possible to obtain it from there
