simulating decoupling capacitors responce for voltage regulator output circuit
yef smith
Joined Aug 2, 2020
1,481
Hello, I have a voltage regulator which have two massive decoupling networks connected to it.
I know that these netorkd suppose to filter out noise.
I tried to simulate the right network as shown below in AC simulation however as you can seeinput is connectoed to output.
Where did i go wrong simulating the responce of the decoupling network?
Thanks.
Alec_t
Joined Sep 17, 2013
15,156
If you are using ideal voltage sources in the sim there shouldn't be any noise to filter out.
Try using non-ideal components (i.e. with some finite resistance, parasitic capacitance or inductance, noise added).
