- Joined Jan 23, 2018
- 28,595
Crutschow is right!! I had one of those regulators oscillating at several megahertz and none of the voltages were even close to right. Use the recommended value, 0.1 Mfd, or possibly 0.33Mfd, right at the IC. The 10 Mfd caps can be farther away. And you will need a heat sink.If the capacitors are getting hot, that would suggest the regulator is oscillating.
Try 0.33μF ceramic caps directly from the input and output pins to its ground pin.
Using a constant-current sounds like a good idea as it converts resistance linearly to voltage, thus making the pressure reading linear.
But you would need a separate constant-current source for each sensor.
