Voltage multiplier having arcing problem not always some time
Vir.paksh
Joined Oct 25, 2018
Hi everyone,
I am having arcing problem with my voltage multiplier circuit for two stage, Step up transformer output = 5500V at 35 Khz, Capacitors used here 102,30KV(1nf,30KV) in multipliers with diode UX-F15B. Any solutions for this arcing issue
AlbertHall
Joined Jun 4, 2014
12,652
Greater distance or a piece on suitable insuator between the places where the arc occurs. If the arc is across the surface of the PCB then you could mill a slot between the two points to decrease the possibility of an arc.
Reloadron
Joined Jan 15, 2015
7,922
If the arcing is in air you may want to apply some corona dope and if the arcing is in an oil bath submerged you may want to remove the board, thoroughly wash down the board and then apply some corona dope.
Corona Dope
Ron
