Voltage Mountain
FrankoKratia
Joined Jun 2, 2021
I have a 12 volt source that I need to boost to 19.5 DC to run a laptop and back down again to charge a battery to run a 12V inverter to run a monitor and other things. How would you guys suggest that I proceed?
38,946
Use a dc-dc boost regulator to get the 19.5Vdc from the 12V source.
Run the 12V source directly to charge the battery (what type), and run the monitor and other things.
It would be inefficient to increase the voltage and then reduce it again.
FrankoKratia
Joined Jun 2, 2021
The battery type is Lithium ion.
The 12V source is a constant voltage source though, and other things run on it. I don't want to battery back up that voltage source. I would rather pipe that voltage source into a setup that can charge a battery, run an inverter, and power my other things without having to battery backup the incoming 12V rail.
FrankoKratia
Joined Jun 2, 2021
Ok my bad. Ok, so I have a 12 volt connection that I dont want to permanently attach a battery to. Such as, in the even of a power failure of that circuit, I dont want my system to take on the load.
I would much rather take the power from the 12 volt source to run my own system, which has its own battery. So that in the event of power failure of the 12 volt line, my system retains power on its own rather than doing so while also providing power to the 12V circuit.
ElectricSpidey
Joined Dec 2, 2017
3,370
Your only solution with those requirements is to boost then buck...how else would you do it?
If you can afford the voltage drop, a diode can isolate your system from the source.
