Voltage Measuring Circuit
Peter523
Joined Aug 15, 2021
97
I would like to construct a circuit that measures the differential voltage on the load of the circuit depicted below :Screenshot_3.png
I think about something with an op-amp. Could please anyone help?
Peter523
Joined Aug 15, 2021
97
Use an instrumentation amplifier. You can get one in an integrated package or you can build your own with chicklets (cheap individual opamps).
As i obeserve, instrumentation amplifiers mainly consist of 3 op-amps. Is there maybe anything with one op-amp?
You will need to look at an IA. There are lots of caveot to worry about. generally IA's measure very low voltage signa;.
Power supply, commn mode range, frequency response, isolation will get you.
Look at Analog Devices and TI.
Peter523
Joined Aug 15, 2021
97
As i mentioned i am not interested right now in choosing an Integrated Circuit but i would like to design one
38,702
Why?
You already said you could us an opamp, which is an integrated circuit.
What's the difference between that and an instrumentation amp integrated circuit?
You can design a differential amp using one op amp and four matched resistors, but it will have inferior performance compared to an instrumentation amp.
Peter523
Joined Aug 15, 2021
97
Why?
Ok, i understand what you mean and i will consider the solution of and instrumentation amp IC. When you say a differential amp using one op amp and four matched resistors you mean something like this? : Screenshot_4.png
If yes, do you know how should i choose the resistors values?
Also in refer to instrumentational amplifier, i want one which is able to measure 0-4V load voltage , and can operate with 3.3 or 5V supply. Also, its output should not be over 3.3V
dcbingaman
Joined Jun 30, 2021
1,065
Ok, i understand what you mean and i will consider the solution of and instrumentation amp IC. When you say a differential amp using one op amp and four matched resistors you mean something like this? : View attachment 245799
If you want a difference amp all four resistors have the same values. If you want a difference amp with amplification, then Rf and Rg must have the same values and R1 and R2 must have the same values. Under these conditions the output is (Rf/R1)*(V2-V1).
The circuit will always be inferior to a true chip designed for that purpose because you must match all four resistors very accurately, at least 0.1% or better tolerance parts. These will be more expensive than just using an instrumentation amp. Not to mention will requires more parts.
Also notice the non inverting input impedance is R2+Rg and the inverting input impedance does not match it at just R1. The InAmp has built in followers with extremely high input impedance along with a single external resistor that sets the gain.
dcbingaman
Joined Jun 30, 2021
1,065
There are plenty of InAmps on the market that can meet those requirements. Here is over 34,000 choices many that meet your requirements. You can refine the parametric search:
https://www.digikey.com/en/products...BcDaIJYDsDOAXATgVwLYFMEoEMU4B7BAAgKwAcQBdAXyA
DickCappels
Joined Aug 21, 2008
10,662
Peter523 (TS) has not mentioned gain or CMRR requirements so we cannot tell whether the advantages of an integrated instrumentation amp is worth the additional cost, sourcing issues, etc.
@Peter523 what is your required accuracy?
Peter523
Joined Aug 15, 2021
97
Thank you, with a quick simulation with these values it seems to work. But, of course you are right the circuit is inferion to an IC for this purpose so i may search and select one of this kind.
Peter523
Joined Aug 15, 2021
97
My required accuracy is about 3% , for example if the real value is 5V the measured output could be approximately 4.9V or 5.1V
Peter523
Joined Aug 15, 2021
97
Hello again,
finally i will follow the solution with the instrumentation amplifier. But as i know each IC has limits in regard to the range of differential voltage it can measure. For example, can i use the same instr amp IC to measure the differential voltage on different loads (the one with 12V on it, the other with 5V on it etc.)? I found this IC and it refers in page 2(at maximum ratings) :1630187614026.png
Could anyone explain please?
Thank you.
Papabravo
Joined Feb 24, 2006
22,107
It means that input signals can be in the range of 0.5 volts below ground to 0.5 volts above Vcc. This suggests clamping diodes on the input terminals which can dissipate some current but not a great deal as the diodes are probably "small" in terms of die area.
It would be handy to know what limits there are on the supply pins. Fragments of a datasheet can cause one to jump to unsubstantiated conclusions.
