I need your help to analyze this circuit.
While I was looking for a plasma cutter voltage meter, I came across this schematic.
I'm curious about how this circuit can measure voltage when the output has a voltage of only 0.6 to approximately 0.8 volts.
Can an optocoupler have a variable output? Does that mean that the voltage of the output signal can change depending on the input?
