voltage drop homework
MrAl
Joined Jun 17, 2014
13,783
You could start by analyzing the circuit then using that result try to think of what might be wrong with it.
WBahn
Joined Mar 31, 2012
33,111
Are you just looking for someone to take your poll?
I'm gonna go out on a limb and guess that "Any" is going to win.
It will help others help you if you take the time to edit your pictures so that they aren't 10x as big as they need to be and so that they are oriented correctly.
As for where to start, here's a hint. Read the problem and do the first thing they told you to do: "Redraw the circuit and use the following values."
Then look at that redrawn circuit and see which measurements don't make sense for the circuit as drawn.
shoff
Joined Feb 20, 2017
14
I rewrote the circuit so far and then broke it down to a single circuit...then I'm stuck on an answer to what's the problem in the circuit?
WBahn
Joined Mar 31, 2012
33,111
And are we supposed to use crystal balls or remote viewing to see what you did?
How can we possibly tell you where you went wrong when you won't show us your work?
WBahn
Joined Mar 31, 2012
33,111
I'm getting an error when I try to open the attachment in the body of the post (but I can see the image file that was attached -- is it the same thing?).
What is "circuit 2" -- and how does it relate to Problem #3.
Which resistor is shorted? How do you know? Area all of the readings consistent with that resistor being shorted?
MrAl
Joined Jun 17, 2014
13,783
By analyzing, I should add r1+r2 ...r3+r4 to make a series circuit?
In case you have not figure it out yet, yes you add R1+R2 and separately R3+R4, then compute the two results as being in parallel. You can then calculate the current and compare it to the specified value. You may also have to use current division to figure this out.
This most recent upload of yours however does not show your determination of what is not right.
Here is an improved version of your upload. Nice hardwood floor BTW :)
shoff
Joined Feb 20, 2017
14
shoff
Joined Feb 20, 2017
14
Ok , thanks to everyone so far ... I have broken down this equation & not sure if it's correct? Cannot find anything wrong with circuit?
WBahn
Joined Mar 31, 2012
33,111
Why do you keep forcing people to open files that are several times larger than they need to be and require people to read sideways. In less than one minute (literally) using Paint or (other the equivalent on whatever OS you are using) you could have posted this instead:
What is the total current you are expecting?
What is the total current that is being measured?
Are these acceptably close? If not, then you have a problem.
The next step is to ask yourself what single component failure could turn the circuit from what you expect into one that matches the measurements.
Ask yourself what you would expect the voltages and total current to be in the eight most likely failure modes, namely one of the resistors failing as either an open or a short.
You can narrow this down before you even start. Consider the two basic failure modes -- open and short.
If one of the resistors fails as a short, do you expect the total current to be greater or less than what you expect?
If one of the resistors fails as an open, do you expect the total current to be greater or less than what you expect?
Which of these is consistent with the discrepancy between what you expect and what the total current is?
shoff
Joined Feb 20, 2017
14
shoff
Joined Feb 20, 2017
14
Thank you ! the step by step process to begin to figure this out is great info ..I'm kinda lost as you can see , I will send my future files in a better format before I post next time ..thx
shoff
Joined Feb 20, 2017
14
Look at R1 and R2. How can you have 12V across R1 and 0V across R2?
I'm not sure ? I'm thinking the technicians readings are incorrect and voltage across circuit 1 have been misread? according to all of my calculations? but any input would be helpful .thx
shoff
Joined Feb 20, 2017
14
Not likely.
Check the reasoning for the calculations you did for I1 and I3.
What does Kirchhoff's Current Law tell you?
r1 voltage drop (270)(0.0154)=4.158
r2 voltage drop (570)(0.0154)=7.854
=12.012
r3 voltage drop(470)(0.015)=7.238
r4 voltage drop(330)(0.0154)=5.082
=12.32
the sum of the applied voltage drop in a series circuit must equal the applied voltage .
so still not sure on why e2 is o v ?
WBahn
Joined Mar 31, 2012
33,111
Think about what you are saying. The problem makes it very clear that there is something wrong with the circuit -- the entire point of the problem is for you to figure out what the most likely problem is. You are given the results of measurements made on the actual circuit to use in making that determination. The fact that there is something wrong means that the measurements will not be what you would expect based on the circuit schematic. Does it really make sense to conclude that the measurements weren't done correctly?
This is like being told that the tires on a car are wearing abnormally and, when told that the tire pressure measurement is 20 psi, concluding that the person taking the reading must have misread the pressure gauge since the tire sidewalls clearly state that the tires are supposed to be inflated to 35 psi.
WBahn
Joined Mar 31, 2012
33,111
=12.012
=12.32
Because one of the resistors is NOT the value that it says on the schematic!!!!!
